SmartSDR Version 2
SmartSDR Version 2
Your Price: $199.00
In Stock
Part Number:SSDRV2
Choose Options
Radio ID
17 chars left
NOTE: For your radio to be licensed it must be connected to the internet. If it is directly connected to your computer then it is not connected to the internet. The simplest solution is to connect the radio directly to your home router and then reboot your radio. This will allow the radio to communicate with our server.
SmartSDR Version 2 with SmartLink
Remote operation made beautifully simple.  That’s the best way to describe the new SmartLink capability included in SmartSDR Version 2.0 available immediately for download.  Finally, remote operation that just works.  No boxes to buy, no complicated VPN to set up, no remote desktop, no computer required, and no complexity.  Just download, upgrade, purchase, register, and operate from anywhere at any time.  Remote so simple you’ll think it's magic!
When you register your radio on the FlexRadio cloud server, you have the convenient option of using your Google or Facebook login or create your own secure account credentials.  From that point you can securely connect from any remote Maestro, PC, Laptop, iPhone, or iPad.  If you have multiple radios, they all show up in the radio chooser.  Simply select the radio and our server securely connects the remote client device directly to the radio so you can operate just as you would running SmartSDR at your home station.  You can even use logging applications remotely using the new SmartLink enabled SmartSDR CAT interface.
**All software sales are final**
**Following local regulations regarding remote operation is the responsibility of the user - Please take note of regulations in your region**
