Radiosport RS60CF headset with M207 mic element
Your Price: $299.00
In Stock
Part Number:FHS-M207
Choose Options
Headset to Radio Cables (select on or more) help
All FLEX-6000s (8-pin Foster) [+$89.00]
FLEX-6500/6700 Balanced Input (XLR) [+$89.00]
Maestro [+$89.00]
MiniXLR 6P Headset interface for 6400(M)/6600(M) [+$99.00]
Optional Radiosport Mic Elements help
Radiosport M208 wide range dynamic mic element [+$58.00]
Radiosport M360 wide range condenser mic element [+$33.00]
Radiosport M350-ADJ condenser mic element [+$48.00]
Radiosport Accessories
PTT Footswitch - 7' cable with RCA plug [+$59.00]
PTT Hand switch, dual action - 7' cable with RCA plug [+$89.00]
PTT Extension cable, 5' [+$26.00]
PTT adapter - 3.5mm plug to RCA plug [+$6.00]
  • Description
FlexRadio Systems is proud to announce a special FlexRadio branded RS60CF headset from Arlan Communications. The FlexRadio branded Radiosport headset is a high quality carbon fiber finish stereo headset with cloth covered deep gel ear muffs that provides 24dB of acoustic noise reduction.  When combined with the soft FlexRadio branded pillow-top headband cover this headset offers unparalleled comfort when wearing for long periods of time.  The flexible mic boom comes with the M207 mic element installed and is adjustable to over 200 degree of rotation for optimal mic placement.  The headset features a waterproof integrated Push To Talk (PTT) button on the left ear cup and an industry Standard miniXLR 6-Pin radio port for interfacing to a variety of radio connecting cables (sold separately).
One advantage of the Radiosport RS60CF headset is that it features a quick change military style mic connector allowing for interchangeable dynamic or electret condenser mic elements to fit your particular operating style and need.  For example, since the headset comes with the M207 element, if you desire a wider frequency response range mic element for rag chewing or ESSB operating, you would select one of the optional wide range elements such as the M208 or the M360  (see Optional Radiosport Mic Elements above).
This headset comes with the M207 mic element pre-installed.  This is a Mil M101 style high output, noise canceling microphone with a dynamic element ideal for DX and contesting.   It provides true communications range frequency response for the utmost in voice articulation with the punch you want to break those tough pile-ups.
M207 Mic Element Features:
  • High output gain dynamic element
  • 200 Ohm Impedance
  • Frequency Response: 300 to 8000 Hz
  • Acoustic noise cancelling design
