RJ45 Cable For the FHM-1, FHM-2 and FHM-3 Microphones $14.99 This adapter cable connects an FHM-3 or FMH-1 microphone to the FLEX-3000, FLEX-1500 or Maestro via the modular RJ-45 connector. Please note that some FHM-2 microphones may not be compatible with the Maestro and have been replaced by the FHM-3... Add to Cart
RCA Plug to 1/4in (6.35mm) TS Mono Jack Adapter, Gold Plated $10.99 This adapter is used to convert a 1/4 inch TRS Mono to RCA primarily for PTT input on the FLEX-6X00 series radios.
Microphone cable RJ-45 to 8 pin foster $24.99 Coiled mic cable with RJ-45 — 8 pin foster connection6 feet when fully stretchedFor FHM-1 and FMH-2's. Add to Cart
INRAD M-YM RJ 45 adapter $19.99 INRAD series M-YM adapter forRJ-45 modular jack transceivers. Use this rig mic jack adapter with the cable supplied with INRAD M-series microphones when the microphone is not in use with the INRAD DMS-1 PTT base. Add to Cart
INRAD M-Y 8 Pin jack adapter $19.99 INRAD series M-Y adapter for 8 pin transceivers. Use this rig mic jack adapter with the cable supplied with INRAD M-series microphones when the microphone is not in use with the INRAD DMS-1 PTT base. Add to Cart
INRAD M-F cable for 3.5mm FlexRadio 6400/6600 $19.99 INRAD series M-F cable for3.5mm stereo mic jack FlexRadio 6400/6600 transceivers. Use this cable instead of the cable supplied with INRAD M-series microphones when the microphone is not in use with the INRAD DMS-1 PTT base. XLR 3 pin connectorfor... Add to Cart
INRAD M-650 microphone $89.99 M650 is the M Series counterpart to the M629 that provides well articulated overall audio with overall higher-end output punch for contesting and DX operation. Featuring a unique cardioid dynamic element with a response pattern similar to the M629, the...
INRAD M-629 microphone $89.99 The INRAD M629 is a wide frequency range, unidirectional cardioid dynamic microphone ideally suited for rag chewing and ESSB. It features a large 1.125" diaphragm and an internal rubber element suspension system for reducing undesirable noise. Excellent... Choose Options
INRAD DMS-650 desk microphone $169.99 The M650 microphone is the M Series counterpart to the M629 that provides well articulated overall audio with overall higher-end output punch for contesting and DX operation. Featuring a unique cardioid dynamic element with a response pattern similar to... Choose Options
INRAD DMS-629 desk microphone $169.99 The INRAD 629 microphone is a wide frequency range, unidirectional cardioid dynamic microphone ideally suited for rag chewing and ESSB. It features a large 1.125" diaphragm and an internal rubber element suspension system for reducing undesirable noise...
INRAD DM-YM RJ 45 detachable cable $19.99 INRAD DM-YM detachable coiled cable for DMS-1 base. 4 pin XLR female to RJ-45 modular for FlexRadio mic jack. Add to Cart
