Holiday Special Maestro Bundle
On sale $1,377.00
Retail Price:$1,467.00
Your Savings:$90.00(6%)
In Stock
Part Number:HolidaySpecialMaestro
Choose Options
Accessories
Maestro Tilt Feet [+$99.00]
Maestro Dust Cover [+$49.99]
  • Description
Holiday Special offer - Maestro with Radiosport Travel Headset - $50 off and FREE headset case
Offer expires 12/24/18
Introducing Maestro™ - an intuitive, plug-and-play control console that directs operation of any FLEX-6000 Signature Series transceiver without need of a traditional PC.  Connect Maestro directly or through your local area network (LAN) to any Flex 6000 series transceiver and you are ready to operate.
Maestro places the most frequently used controls directly at your fingertips.  Controls are labeled for intuitive operation and designed to minimize hand motion for the most common operations.  Occasionally used controls are easily accessible on the large touch screen display bypassing the complexity of multi-function buttons and multi-level menus found on most transceivers.  Like modern phones and tablets, capacitive touch control is provided on the large LCD display for intuitive pan, zoom, tune, and menu operation.
Please allow 2-3 weeks for shipping
For more technical information on Maestro, just download the Maestro Product Brochure or visit the Maestro product web page.
Suggested Battery packs (not sold by Flex Radio)
    FlexRadio Systems recommend that you follow the recommended manufacturer's instructions for charging the battery pack.  Not all battery packs can be charged while the load or the USB drain cable is connected.  For ensured safety, disconnected the load or the USB drain cable when charging the battery unless explicitly allowed by the battery manufacturer.  FlexRadio will not be responsible for any damage to the Maestro due to battery charging related issues.
    The batteries below meet the following specs:
  • Maximum Battery Size: 3"W (7.62 cm) x 6"L (15.24 cm) x 0.75"D (1.91 cm)
  • Power Connector: USB-A female
  • Recommended Current Supply: 2.5A at 5V DC output
  • Auto Start: Preferred feature - initiate start on introduction of a load
Possible types:
  • Polanfo M50000 Portable Power Bank (12000mAh)
  • Mogix Accessories (10400mAh)
  • EasyAcc 2nd Gen Power Bank (10000mAh)
  • NINETEC Power Bank (15000mAh)
