Heil Proset HC6
Heil Proset HC6
Your Price: $153.99
This item is not yet available for shipment. When ordering this item you will be placed on a waiting list.
Part Number:MC-PROSET-HC6
Choose Options
Headset cables
None
Proset to FLEX-6000 [+$23.98]
Proset to FLEX-5000 [+$23.98]
Proset to FLEX-3000 or FLEX-1500 [+$23.98]
Push to talk
None
Heil Hand Switch [+$33.95]
Heil Foot Switch [+$44.00]
  • Description
Headset cables for connecting the ProSet HC6 to the radio are sold separately.  Refer to the options above.
The Heil Sound Pro Set is a lightweight, versatile boom mic/headset designed for comfort, durability, and, above all, performance. The earpieces are full sized (4"), with heavily-stuffed cushions for operator comfort during long operating stints. The earphone speakers in the ProSet Series are 200 Ohm devices, with a -3 dB point at 8000 Hz for reduced listening fatigue. The ProSet headset is equipped with the Heil HC-6 full-range element that has a low frequency roll-off at 300 Hz that facilitates good communications quality audio. Each Pro Set is equipped with a windscreen for the microphone. The windscreen does not affect the frequency response of the microphone, and it is highly effective in minimizing breath blast while you`re speaking.
