Maestro C Y Cable Kit $15.00 Maestro C - Headset Cable Kit 3.5mm Microphone 3.5mm Headphones CTIA Stereo Jack Y Cable 1/8" TS to RCA adapter for PTT This is ideally used to connect your Flex FHM-3 Microphone to your Maestro C. It will allow you to... Add to Cart
Previously loved FLEX-6400/6600 Extended Transmit Module $299.00 $399.00 Previously loved FLEX-6400/6600 Extended Transmit Module Required for MARS, Shares or other users who require out of amateur band transmit. A government issued license is required to enable this option. A TURF file will be provided by our support...
Maestro Monitor Cable & Adapter $29.99 The HDMI Adapter Kit, which comes with a convenient right-angle 90-degree adapter and a 5-foot HDMI cable. This kit is perfect for effortlessly connecting your Maestro C to an external monitor. Plus, the Maestro C boasts a stunning resolution of 1920 x... Add to Cart
Maestro C Battery Charger - Double $260.00 RRC-SMB-MBC – RRC SMBUS Mini Battery Charger Dual bay battery charger for the RRC-2054-2 battery. AC Power Supply included Optimized charging process for RRC batteries Longer cycle life Faster charging Simple Operation Required to... Add to Cart
FLEX-6000 Series Version 2.x SD Card $30.00 A backup SD card for your FLEX-6000 Series Transceiver. This card is installed internally on your radio and it does require you to remove the covers of the radio (#8 Torx). Some internal disassembly of models 6300, 6500 and 6700 is required to... Choose Options
FLEX-6000 Series Version 3.x SD Card $30.00 A backup SD card for your FLEX-6000 Series Transceiver. This card is installed internally on your radio and it does require you to remove the covers of the radio (#8 Torx). Some internal diassembly of models 6300, 6500 and 6700 is... Choose Options
FLEX-6500/6700 Handle Kit $75.00 Signature Series Handles for FLEX-6500, FLEX-6700 and FLEX-6700R (Not installed at factory) Add to Cart
USB to Serial adapter for the FLEX-6000 series $49.99 This cable plugs into the USB port on the back of the FLEX-6000 series radios to connect to devices requiring a serial connection. This functionality requires SmartSDR version 1.10 or later. Included is an RS232 Null Modem Female to Female adapter to... Add to Cart
USB to Parallel adapter for the FLEX-6000 series $69.99 This cable plugs into the USB port on the back of the FLEX-6000 series radios to connect to devices requiring a parallel connection. This functionality requires SmartSDR version 1.10 or later.The cable is terminated by ten individual wires with single... Add to Cart
Sale Tilt Hinge Feet for Maestro A or B Model $49.99 $109.00 The tilt hinge feet option for Maestro (A/B models only) are constructed from black anodized NC machined aluminum. The variable viewing angle is maintained by14 in-lb constant torque hinges that do not require any sort of torque adjustments. The feet... Add to Cart
